KA24DE pilot bushing question
MoSinister
Car: '95 S14 KA24DE
Ok, my brother and I are to the part where you grunt, groan and swear trying to get the transmission stabbed back into the pilot bushing before bolting back up. We aren't even getting to the alignment pins. The trans stops dead with about an inch gap between the transmission housing and engine mating surface.
I am beginning to question whether I inserted the new pilot bushing far enough. I stopped tapping it in when it was flush with the bore. Is it actually supposed to be recessed any at all? Is there a lip for "bottoming" it out inside the bore? I was a little quick removing the old one, so I don't remember if it was flush with the bore opening or recessed.
We have no idea if the splines are even touching the friction disk. There's not enough clearance to see between the flywheel and bellhousing and the throwout bearing is blocking the view through the dust cover port.
Regards.
Modified by MoSinister at 4:37 PM 9/26/2007
Modified by MoSinister at 4:41 PM 9/26/2007
NM50
Car: 94 D21,98 03 hummer H2,66 311 CA18ET ROADSTER,94GEO METRO pimp mobile
If its flush with the crank it will go.Recheck your clutch disc alignment.
pr240sx
Raise the rear of the transmission as up as you can.
churro
Car: RHS13 ('89 Hatch)
I'm having the same problem but with a KA24E. It just needs like an inch to close the gap. I'm not sure what the hell is in the way.
tramp_drift240
Car: 1992 240sx SE Coupe
TO THE TOP.
whats with the gap? isnt the input shaft supposed to just pop in when the angles right between the block and the bellhousing?
i keep having the same problem, having a little bit of gap, and it doesnt seem to want to close up.
i just changed my pressure plate DUE TO THE BROKEN FINGER, and the pilot bushing, because my last one got all dented up from people attempting to help get my motor in and close that gap...
but now theres still a bit of gap.
im confused
nep
tramp_drift240 wrote:TO THE TOP.
im confused
im stuck here too. what did you guys do to close the gap?
5upra
Car: S197
no actual experience with this motor but should just slide on....if it will not something is wrong, or the opposite if theres nothing wrong put your back into it.
trying turning engine to make get splines to line up...once that is good should like i said slip right on.
Modified by 5upra at 1:57 AM 10/29/2007
