KA24de Performance Headers.
mickeyd420
Car: s13 92 se
Beside the header itself what else is required to install. Will a hotot header install effect my engine in a negative way?
The Hotshot is the only header I'd recommend for the KA... it's well-built and fits good.
No reason not to install one.
TDS
Car: 2008 G35
make sure to pick up a new exhaust manifold gasket to replace the old one.
mickeyd420
Car: s13 92 se
also .. when i get a intake. Is it necessary to buy the piping or can i jus use existing plastic piping and smack on a maf and air filter after market of course..wat do you guys recommend?
Iceman00
Car: cars women
AZhitman wrote:The Hotshot is the only header I'd recommend for the KA... it's well-built and fits good.
Hotshot is no Longer made. OBX should be a direct copy of hotshots design, and DC Sports header is supposed to be really good.
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
I'm currently using an OBX and it works fine...
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
mickeyd420 wrote:also .. when i get a intake. Is it necessary to buy the piping or can i jus use existing plastic piping and smack on a maf and air filter after market of course..wat do you guys recommend?
Buy a K&N drop in replacement stock panel filter, you will get more power out of it versus the air cone unless you want that whooshing/sucking sound.
Iceman00
Car: cars women
vocationalzero wrote:Buy a K&N drop in replacement stock panel filter, you will get more power out of it versus the air cone unless you want that whooshing/sucking sound.
Doubtful.
MXMOVRDV
Car: 94 240sx vert 66 mousestang
Hey, I bought an OBX header and it fit's fine to the engine and the pipe's to egr valve and pair valve hose and o2 sensor. The problem I have is where it goes up under the car along sub frame is it is 1/4" to 1/8" from bottom of the car. IS THIS NORMAL? If so I will carry on and finish installation. It is 94 vert. Putting on a complete system ft to back
psi240
Car: 1997 240sx
anyone using the ebay ones 4-2-1 style? at $100 shipped its tempting.
superficialfilter
Car: 1997 240sx se
Yeah I bought one. Its been on for alomst 2 years and havent had any problems so far(keepin my fingers crossed). I had to fabricate an EGR tube for the thing because it didnt even come close to lining up with the stock tube. For the amount of work involved in doing it right (functioning EGR) it was a complete waste of time and money. Not worth it. It looks cool but thats about it in my opinion. Here are some pictures.
pflicht
Car: 1991 Nissan 240sx - SOLD
2000 Lincoln LS - DEAD
1997 Nissan Maxima - DD
1991 Nissan 240sx - Project
So if we don't have to worry about all of that EGR bullshyt, then the ebay header is actually good?
superficialfilter
Car: 1997 240sx se
Its not worth it even if you dont bother hooking up the EGR. The gains I saw from installing it were minimal at best. I probably benefitted more from loosing the weight of the stock manifold than anything. Trust me when I say that reality will fall far short of the impression received. And that applies to alot of these "upgrades" they are selling. Then there is the issue of quality. I know I'm going to have future problems with this thing rusting through or a weld breaking loose. Good thing I still got the manifold. Even thought it only cost $75 its $75 dollars I could have saved towards something else that will yield better results like a turbo kit(which is what I'm doing), sway bars, springs, etc. Save your money.
sant
Car: 1990 240SX
EBAY HEADERS WORK FINE BESIDES FITMENT ISSUES
