but the upper rad hose is very hot, which leads me to believe its the thermostat...
i thought the thermostat is linked to the
lower radiator hose
bleeding the system is a PITA for nissans... i'm thinking of getting one of "those burp funnels" for my next cooling system service
(i LoLed at the way the FSM caters into burping the cooling system for the minivan~ you got to do a makeshift IV jug with a windshield washer bottle and some hose)
i guess if the gaskets on the rad cap is bad, doesn't hurt to change it as part of the maintenance.
are you using OEM or aftermarket t-stat?
from another site:
I did more research and found that the stock Nissan thermostat is a lot different from the crappy Autozone OEM ones. The bleeder hole is much higher and has a bigger bleeder to fix the bleed/bubble problems with these motors.
So in the meantime, since I am too broke to buy parts right now, I drilled a 1/8in hole in the top of the thermostat above the bleeder hole in the OEM one from Autozone. I used a large funnel in the radiator to bleed the system and utilized the bleeder valve again on the manifold.
...the nissan was more bulky, had a larger coolant flow hole, as well as larger air bleeder hole. It operates a lot better than the autozone..thing.
...autozone bleed hole is real close to the middle vs the nissan being near the edge
I was lucky that i've used a stant / aftermarket one & has bled the system properly, using that bleed bolt by the coolant sensors, jacking it up, heat on full HOT, etc.
the next time that i'll be going to change the t-stat will be to either drill a small hole on the aftermarket, or get an OEM one.
PS: is the cooling fan working? belt-driven clutch fan ~ the silicone,oil inside may have bled out & it's easy to diagnose by putting your finger in the center of it & check if the fluid leaked out of that clutch
when i was guessing why the fan wasn't moving alot of air when hot, i stuck my finger around the center of that fan clutch and felt the oily residue that had leaked out of the unit...
if you have jury-rigged electrical fans on it, then disregard the last part of my post & verify if the fans are working
