Ky24D »
https://forums.nicoclub.com/ky24d-u32656.html
Sat Sep 17, 2005 11:36 am
I am having the same problem with a 93 KA24DE. I have replaced the thermostat twice now, I bought the stat at Napa both times(I have heard that an OEM stat would be the fix) But I bleeded the system with the bleeder screw, filled the radiator up. Then started the car with the heat on, ran it till it got hot and it never drained down to my heater core, the antifreeze just bubbled out of the radiator. And recently i have noticed that when i fill my reserve box with antifreeze and drive for a few miles, and when I check again the box is empty...???? The car, running idle will stay at normal temp on the gauge. But once I drive for a few miles it jumps up to hot. What could my problem be?
