MonsterM3 »
https://forums.nicoclub.com/monsterm3-u185802.html
Sat Jun 11, 2011 11:58 am
hey guys, a few days ago i replaced my water pump because it was leaking from the bottom weep hole. everything worked fine for a few days until yesterday while i was driving i noticed the water temp. gauge had risen all the way to the hot side. i pulled over and shut the car off immediately. i checked for coolant leaks and came up with nothing, so i thought it may be a stuck thermostat. i let the car cool down then i limped home.
so today i replaced the thermostat and took it for a test drive. sure enough, its still running hot. i dont know what else it could be. is it possible the water pump is faulty? its a re-manufactured one from Advance. i took it back out but it spins fine by hand. can anybody help?
