Unstock240 wrote:I just drove 60 miles with no problem, mostly highway. Then on the 60 miles back it was fine all the way till I pull in my drive. Just then it starts to heat up and I hear gurgling. It seems to get hot after a long drive, then a few idling or slow moments it goes up, high rpms will sometimes bring it down. I have 3 clutch fans and all have about the same resistance so I dont think thats the problem either.
Modified by Unstock240 at 8:18 PM 9/15/2009
Obviously by this statement you very obviously need a new clutch fan. Not a doubt in the world. No need for any further discussion until you have replaced the fan, put in a Nissan themostat, and bleed the system. No need to post anything else OP. Put a new clutch fan in it, and it will stop overheating.
I mean think about it. You drove 60 miles and it didnt over heat until you stop, therefore, while driving there is air passing through the radiator and cooling your engine. When you stop. guess what, there isnt anymore air passing through the radiator to cool it. Thats where the clutch fan comes in. If you are missing the shroud, then make sure to replace the shroud when you replace the clutch fan.
Also, the clutch fan is not the fan itself, it is however the clutch hub that the fan bolts to.
FIX IT.
