Royalspade wrote:when you compeleted four revolution, they all stayed at 130?
If so you might wanna check for a slip timing belt or chain... or your rings are bad.
if your car over heats when driving and not at idle.... it could be your fan, because you said you thermosat was good rite and also your water pump.
your car should overheat at idle if the thermosat is bad.. do you put just water in your radiator... or you use coolant water may have corrod your water pump, since it contain sulfur.
1.) Ka's are chain driven
2.) slowfkncar said he took his t-stat out, duh no wonder its over heating t-stats are there to slow down the water, to allow the air passing through the radiator to effectivly cool down the coolant/water before it returns to the engine, no t-stat no cooling
3.) not sulfur, calcium is the water pump/ cooling system killer
4.) i believe 130 psi is normal across all cylinders, you shouldn't see more than a 5 psi difference between all cylinders
-Mike
