koukiKA240 »
https://forums.nicoclub.com/koukika240-u16651.html
Fri Sep 16, 2005 11:17 am
After spinning a bearing in my KA-T, the oil pump saw some shavings. The factory tollerences are all well within spec and i was going to reuse it. The 2 gears that are inside the housing that make up the actual oil pump have bearing pressed into them, figuring it was most likely lead we took it and had it hot tanked but it didnt come out. So i have a bit of a problem. Toga high volume oil pumps and topline OEM pumps are on nationwide backorder and ive been on the waiting list for 3 weeks now. My housing is fine and i was wondering if anyone made just those 2 inside gears for the pump? Ive nico searched and google search and not come up with anything.Thanks,~Sam
