neverlift »
https://forums.nicoclub.com/neverlift-u39984.html
Tue Aug 21, 2007 7:28 am
yeah its the vss, it came up again so I unplugged it and re wired the thing, it was chop/splice job from previous previous owner, IDK its very strange, I needed yet another jump this morning, and the car has started four more times, I'll be going to the parts store for an alt test today... someone mentioned the fuel pump, I tested the pressure vs rpm it drops when boost falls off(tunrs into vac) and psi goes to normal for vac. I'm lost a bad pump normally is just that, bad meaning car wont start.
I replaced maf cap and coil as well as fuel filter(it was a good 300zx one) I'll be swapping my relay at the pump and hope thats it, as well as getting the sensor from my sohc transmission(vss) I'll be rewiring some of this rats nest I have(I would hav ebought a nother damn harness knowing what I know now) any more ideas guys need this fixxed.
