rapid roy »
https://forums.nicoclub.com/rapid-roy-u124471.html
Wed Feb 04, 2009 6:38 pm
40 - If all you did was swap the distributor than there should not be any alignment issue since the dizzy shaft is keyed to fit into the oil pump shaft. It should not matter where your crank is because the dizzy will only fit in one way (if thats all you took off).
Re-check all distrubutor connections first. Then...If you removed your plug wires, I would check that you re-attached them to the dizzy on the correct points. The firing order should be 1,3,4,2. Check a manual to ensure where the #1 contact should be and the rotor spins counter-clockwise from there.
If your plug wires are correct then maybe try loosening the 2 dizzy hold-down bolts and move the dizzy one way or the other to change the timing a little... I really dont see this as a fix but its worth a shot. If you were even close on your timing then it should start, maybe just run a little rough.
OK, heres one last resort idea... I believe my truck may be set up 180 degrees off. The contact on the dizzy that the book shows to be the #1 is actually wired to the #4 on my truck. and i have it running good now. Maybe if you verify your plug wire are correct and still get nothing, try rotating your plug wires 2 spots and try again.
good luck, keep me posted. - roy
