KGB »
https://forums.nicoclub.com/kgb-u78063.html
Sun Jun 28, 2009 6:50 pm
This is perfect. I just passed my no start competency in wyotech the other week. We know for sure your not getting spark correct? Working from the source of the power to the ignition (relays, fuses, wires) test with a test light the fuses (they have that little hole on the top of each side which allows them to be tested), next check the relays. You can hear or even feel them working/switching (thats what they are esentially). Check for power at the coil. What I would do for this is use a spark tester and see if your getting spark FROM the coil, no spark the coil might be bad OR again open in the wire or fuse/relay is bad. So, if you get power there then you might have an open in one of the wires that gives power to the ignition system. What will help you the most is a wiring diagram which will be hard to read cause its nissan made it compact, youll see what I mean if you can get your hands on it. A few more things, if you get power through all of the components check the PCM and make sure power is going to and from it. Hope that helps.
