97gsx »
https://forums.nicoclub.com/97gsx-u42730.html
Tue Nov 14, 2006 10:15 pm
Ok, we just did the headgasket on my ka24de from a 93 s13. I think the cam's are on wrong, it wont fire even after doing the distributer adjustment.
When you line up the pulley marks at TDC on compression stroke, and line up the #1 plug with the rotor, and put it back together, it still doesnt fire.
When putting the cams back on, we put it at TDC and had the Intake cam's first lobes pointing at about 10 o clock, and the exhaust cam notch pointing at 12 oclock, as shown in the jim wolfe cam install guide.
I dont know what else there is to it that would make it not fire?
It cranks and will occasionaly fire, exhaust pops make me believe its wanting to fire. We got it to fire once but idled very rough and then died.
I searched and found some good info, but if i pull the valve cover off and set the car at TDC via the marks on the pulley, what should i look for for cam placement? also, does it really matter where the upper chain is positioned on the sprockets?
Modified by 97gsx at 9:40 AM 11/15/2006
