borodrifter »
https://forums.nicoclub.com/borodrifter-u56770.html
Sun Dec 23, 2007 10:16 am
I typoed up there. I torqued it in sequenced per the manual and used the corresponding torque values from ARP.
The head gasket is 1mm and iirc the stock gasket is 1.2mm? It could be 1mm stock. I'll have to look. *edit: stock Felpro head gasket measures 1.28mm*
The cylinders where honed, not bored. I just hope they didn't hone them too aggressively and neglected to tell me.
I am checking comp wet, using the starter. No I didn't drop any oil down the cylinder but I doubt it would make much change from 64 psi.
You probably have it right that the rings are lined up at the end gap. Either way it comes down to the machine shop or the performance shop who assembled it. And apparently the engine builder at this shop was fired not long after I had it assembled. Could be a reason, yes?
I hate to be the customer who comes back bitching because my motor blew up, but it's not the "I was racing it and it blew" scenario. This is initial start-up and it's junk. IMO that comes back on them.
