Cholos_D »
https://forums.nicoclub.com/cholos-d-u40160.html
Fri Jul 14, 2006 8:28 am
There is a whole list of things you can do. Some don't even add horsepower, but increase throttle response and acceleration.
-High flow cat or testpipe, your choice-Lightweight flywheel, increases throttle responce,there is a video somewhere of a comparison of the tach on a 240, this will help you see what a difference it makes.-Royal Purple fluids: oil transmission diff (Some say it also frees up a few horsepower)-New spark plugs and 8mm or bigger plug wires-Lightweight forged wheels. I'm not sure how much yours weight, but I have R32 Skyline GTR's and they're 16" forged and superlight. Reducing a pound off your wheels is like taking 8 pounds off your car.(I'm not sure of the exact ratio)-Electric Fan. Reduces drag on the engine. You can get a 16"fan plus wiring and thermostat at Autozone for like 75$. Increases throttle response.-Reduce the weight of the car. Check other posts for specific weights, but you can take over 150lbs. out and still have A/C and powersteering and a somewhat intact interior. Increases throttle response.-Advance the timing of your engine. Check other posts for the numbers. But you'll have to run premium-Aluminum Driveshaft. Once again reducing rotational weight. Increases throttle response.
After that, you start to open the engine up-Camshafts, there are like twice as many to choose from than a year ago. Which ones you get depend on if you'll have to get new valvetrain also.-High compression pistons. '89 or '90, one of the two, the Sohc pistons in your Dohc raise the compression to 11.0:1, at which point you'll derinetly be running Premium Fuel.
The key is to reduce the weight of the car overall and the weight of everything that spins. i.e wheels, flywheel, pulleys, e-fan, driveshaft...Hope this helps.
