the ac pump and that dam bracket it uses is a pretty decent chunck of weight.GTLegend wrote:my AC in the 240 dose not work, so i'm thinking of taking it off along with the clutchfan and go with an e-fan.
You would yield more power, milling the head down and head welding the head.The design of the DOHC piston was to improve swirl and atomization. Once the SOHC piston is used swirl is decreased.GTLegend wrote:
i have a 1995 ka24de i'm rebuilding. here is my plan. stock rebuild with felpro gasket set, oil pump, timing chain ect. but i'm going to add ka24e sohc postions from a 1990', with BC v2 cams, 17lb. flywheel, headers, Hiflow cat, exhaust, intake, some head poolishing done by me, and jwt ecu flash. i might get the BC valve spring kit but i donno if its worth it?
any comment/suggestion are welcome!
keep your 315cc 4age injectors..a cheep and easy ebay mod is a topfeed convertion..just so happens a 315cc injector works perfect for it..and there denso style too!GTLegend wrote:i'm on a budget dude.
sohc pistons are pretty cheap. angle valve job may help.
gotta sell some 4ag parts first.
One that talks crap actually knows nothing. If you had anything fact base you wouldn't be so hard gay, so I'm niot offendend by your ill information....GTLegend wrote:ohhhh... you again!! god sure did bless you with a lot of knowledge bigbinnie. glad to see your putting it to good use! but i decided to go ka-t, but picked up a gt25 from my buddy . going with stock pistons and stock boost pressure. good thing i'm gonna say away from all that "knocking and pinging"!!! hahahaha thanks for all the useless advice! /:>)
No one wants your 4age crap just like you don't want your 4age crap, it's like a little high rev honda engine. Go get a real job and get that mani and down pipe you want so bad.....GTLegend wrote:my AE86 4AGE injectors are from the red top hi-comp motor and they are 235cc from a 1.6L toyota!(if your interested you can by my HKS 4age cam off me on ebay). then i can get a turbo mani and downpipe.
OOOOHHHH I'm creaming in my pants over those super weak sauce numbers. I'm about to pull off those same numbers with stock compression and a NISTUNE. So your buddy wasted his time to make 176WHP with SOHC pistons, and 104 octane. I'm making 162WHP to the wheels on 95 octane, and stock compression, no ecu tune and a weak SAFC. Higher octane would of yielded bigger whp numbers than using teh 95octane, so relative to your buddy installing sohc pistons he probably only yielded 5 maybe 8 more whp than guys using stock compression. Pure weak sauce. seams like you and your butt buddy are part of that elite group of dumb a$$ that can't harness High compression engine power, wonder why?GTLegend wrote:i was gonna do the sohc pistons because my co-worker used them in his NA KA build and made 176whp (w/104 octane) with just cams+bolt-ons, and tuned ecu.
WHO dude..settle down..bigvinnie was tryin to help ya out!...Bigvinny,Angyhippy,Vegascorbin,Razi,and a few others i should mention but im bad with names..are dayly participants helping guys like you...you have no rite to treat people on this forum like that...this is not prostreet,vegasdrift,or the honda forums..this is nicco..we are family..you need to recant your comment..or im afraid you will be held accountable for your comments..GTLegend wrote:ohhhh... you again!! god sure did bless you with a lot of knowledge bigbinnie. glad to see your putting it to good use! but i decided to go ka-t, but picked up a gt25 from my buddy . going with stock pistons and stock boost pressure. good thing i'm gonna say away from all that "knocking and pinging"!!! hahahaha thanks for all the useless advice! /:>)
i was gonna do the sohc pistons because my co-worker used them in his NA KA build and made 176whp (w/104 octane) with just cams+bolt-ons, and tuned ecu. and he drives it everyday no prob. spent less than a grand! the car revs and pulls like a champ, def. noticeable performance increase over my stock KA. he uses 93 oct. daily and there is to pinging or knocking and fuel consumption is the same. the only thing i would change are the valve springs.
Modified by Bigvinnie at 7:41 AM 9/25/2009
your all wrong dude. I have 10 years total, and 5years of serious study on this engine. Your missing the key element to power which is efficiency and unfortunately your to young to understand this. Engine ve at 100% obtainable are what people try to reach, not the theory of power equals a bigger d#ck so to speak. With smog standards most engines fall within the realm of 75% efficiency, especially when it was the era of OBD1, and the beginning of OBD2. You should ask your self what is the best affordable way to harness power and strive for 100% VE.GTLegend wrote: know i'm not a expert engine builder ot race engineer, other ppl need to realize that they aren't either.
one thing i did notice on nissan forum is that a lot of the members are obsested with "more". more power, more tires, more boost, more bore. that dosen't mean that system will be more effective. many times they detune the motor, or reduce the efficiency rating.
HAHAHa well I guess we are in agreement. Your attitude sucks. young Noobie One.GTLegend wrote:please let this be the last post i'm tired, and you have an ego so i'm guess its gonna go on and on, by yourself cuz i'm done with you and you 1million year experience with building efficient motors
HAHAHAHAHAThis is great man. I hope this venting makes you feel special.GTLegend wrote:your lucky that i don't take you seriously, i was gonna tear you a new one..
