SLde_Show_Enthusiast »
https://forums.nicoclub.com/slde-show-enthusiast-u12344.html
Wed May 11, 2005 7:04 am
Hey guys, this is my 1st post, I'm about to pick up a motor that i bought for 300 bucks. It has 69999 miles on it and i'm getting it for 300 bucks. My goals are: Install clutch, break it in and then turbo it, looking to get 220-250whp.
I'm not going all out with boost and will only run 7-9lbs and maybe 10 if i can get to it.
my setup: ssa manifold/dumppipe t25 sr turbo/370 injectors walbro 255lph safc 2 touge factory 3 inch downpipe s13 sr smic with stock bov z32 fuel filter mbc
Basically i'm gonna run the same setup as bluebottlemax
Reason for lower mileage motor: well my car has 180k on it and i'm getting the motor really cheap and the turbo and injectors are going to me for 100 bucks, the safc, downpipe, smic/bov is also going to me for 350 bucks(new), and i will buy the manifold,dump pipe, and walbro from ebay ($300). Gaskets, lines, and fuel filter will prob be $150. 900 bucks total for turbo kit... not to bad
with this setup, moderate boost/power, with little/no turbo lag will be used for autox/drift events.
questions....
While i'm doing the motor swap, i would like to know what I should do while the motor is out the engine bay? I would like to do preventive maintance stuff and not anything crazy like a whole rebuild...because i will eventually/slowy rebuild my 180k motor and have it for a spare.
I know that i will be replacing the rear main seal since i already have the new clutch ready for install... front main seal will also go in. is there anything else you guys can think of that will not put my bank account in the negatives?
Also, the motor was probably sitting in the junkyard for 6months or more, is there anything i should do to lube the motor? Is it necessary for me to drain the oil, pull the valve cover and flush new oil through it? should I change the plugs or just swap my current plugs in instead of getting new ones? Should i also replace starter, alt, water pump with my current ones? should I remove the iaiv valve, egr, etc?
please let me know what should be done with the lowest amount of money involved...
thanks a bunch...
Modified by SLde_Show_Enthusiast at 6:36 PM 5/13/2005
