KA24DE metal head gasket
supra brit
Car: '93 Supra, '94 240sx 'vert
Who makes a metal head gasket for a KA24DE, and preferably one that's not too expensive?
Ubernoober
Cometic.They are all rather pricey. I am of the opinion that the need for this item is a bandaid fix for a more significant problem.
WeldingHank
Car: 1989 240sx CA18DET
because stock paper gaskets last to 500hp?
Ubernoober
Something along those lines.
574-240sx
Car: Nissans, Toyotas, Subaru
I have had a cometic hg sitting in my room the past year. I have yet to blow the stock one with 140K on it. By the way with a metal headgasket if you detonate to bad you will blow a piston/ring landing or a combo of both. Could be worse too.
gabossie
Car: Your mom
Unless you're making close to 500hp, you don't need it and like 574-240sx said, it can cause problems. I would rather blow my headgasket than my piston rings or worse.
supra brit
Good point. Well, I was going to replace it since I'm doing the timing chain this weekend, but if it's not neccessary, I won't do it. Thanks yall
