DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Thu Sep 04, 2008 8:07 am
cams are not really the limiting factor for making power at high RPMs, its really the intake and exhaust manifold.
Okay, just some absolute info in this thread: Sometimes when people put auto ECUs in their manual cars they get a 7200 rpm limit. i dont entirely believe this to be true, but it might be. my stock manual car used to rev to 7200 stock, but only under no load. i jsut did a swap in my buddies car, manual but auto ecu, and his still only revs to 7000. i think lots of it could be resolution on the tach, or maybe something mechanical or electrical.
The point is, on stock cams and intake manifold, you're starting to lose power once you rev over 6500 rpms. Its fine for 1st gear, and maybe stretching out 2nd gear, but thats about it.
NOW, for the actual information from a Rebello engine builder who chimed in on a thread of mine from years ago:
The front snub nose of the crank snaps off because of the harmonics at 8000rpm. on stock crank, 8k will toast your motor. 7500 is safER, but still not useful without supporting modifications. However, the builder did go on to say that the crank pulley bolt hole can be drilled past the first journal (i believe), tapped, and then install a longer bolt, and these motors are safe past 8000rpm, EVEN without a fully weighted crankshaft
with supporting headwork that is
