ka24de maf help
mechpro
Car: 1996 nissan 300zxtt 1984 vw scirocco 1991 240 sx
how can i test my mass air flow sensor on my 94 ka24de?
maniacman9558
Car: 93 240sx n/a KADE (for now! =P)
05 ninja zx10r
what i was told and worked for me was start the car and unplug the maf while its idling and if it runs better then your maf is bad..if it gets worse then its still ok.
xekushnr
Car: '90 Nissan 240SX Hatch
maniacman9558 wrote:what i was told and worked for me was start the car and unplug the maf while its idling and if it runs better then your maf is bad..if it gets worse then its still ok.
Thats the gist of it. If it idles better or the same then the MAFS is most likely bad. If it idles worse then most likely the MAFS is still doing its job. Just be sure to turn the car off before you plug the MAFS back in, I've heard that can cause issues. Well, it was either that or the TPS, I cant remember. But turn it off first just to be safe.
