Ok so i bought a 1992 240sx se with a ka24de its a 5 speed. It leaks a lot of oil and even haves a weird smell like burning maybe. I leaks where the transmission meets the motor. I thought it was the motor but i added oil and it still stays high even after leaking oil. Could this be the rear main gasket seal ? or is there something wrong with the transmission ? any info would be of great help guys.
thank you very much and here are some pictures of it.
[IMG][/IMG] If you look close you can see the little drip forming [IMG][/IMG] [IMG][/IMG] Dirty oil pan nasty !! [IMG][/IMG] There it goes dripping a lot after a short drive [IMG][/IMG] And there it goes dripping again.
Any info on what this is caused by and how to fix it would be of great help.
thanks guys
dave
