KA24DE knocking... inspection time
niemczykj
Car: 1992 240sx fastback, 1986 Z31 Turbo
the past couple days my motor started knocking... it was a tad low on oil as i was at the end of an oil cycle, and just did an oil change.. (the level was just above the L... not too too low)
anyway my knock has gotten worse and i think i may have some bearing damage. I am set up right now to drop the oil pan and investigate... if something is visibly wrong, i will be swapping rod bearing or w/e is wrong with the motor in the car... idk if anyone has done this before, but i searched and didnt see anything.
I WILL be dropping the front crossmember so i have easy access to everything, and so i can install and seal the oil pan properly with eaz....
any one have any suggestions or tips?
im gonna go start removing the oil pan, via steps from my FSM...
wish me luck, and keep you fingers crossed that this KA is savable...
niemczykj
dropped the oil pan and found metal shavings in it, so im assuming i have some bearing damage but im hoping nothing else..
im going to remove all the rod bearing caps, to check out all the bearings
p.s. thanks mods for putting this in an area where theres no traffic... there is no info on nico about any of this, and i was tryin to find someone with experience, for the first time, nico has failed me
91nissantwo40sx
niemczykj wrote:the past couple days my motor started knocking... it was a tad low on oil as i was at the end of an oil cycle, and just did an oil change.. (the level was just above the L... not too too low)
do you have any idea how it started knocking? did it just decide to give up on you just like that? and how many kms on the engine?
niemczykj
well theres about 80,000 miles on it. i swapped it in, it was leaking oil from the oil pan, and the oil level must have gotten a little too low for a little too long, and i believe it developed the knock from running on low oil.
wcrenshaw61
Car: 95 Nissan 240sx
I have the same problem... What did u find? And how did u fix it? I know this post is several years old, but you left the thread hanging. Thx
