ka24de knock sensor
spooled240
Car: kouki s14
this is a newb question but here it goes im building a ka-t and i heard that stock ka's have knock sensors...is that true? and if it is does it retard the timing if the engine pings? any info would be great thanks
nissanfanatic
Car: 1992 Nissan 240sx SE
Yes it has a knock sensor. For your safety, no it will not retard timing if it sees knock. Its a little more complicated than that. It runs a Knock map which is basically a bunch of overly safe timing and fuel maps.
spooled240
Car: kouki s14
so do you think i should get an aftermarket knock sensor setup?
S13FX
Car: '69 l20b Dimeski :)
I'm pretty sure the it works is, when the DE ECU detects knock it automatically switches over to limp mode so you don't damage your engine?
