If you boiled it and it opened then that would be the only reason why the thermostat's not opening in the car, I guarantee you that you have air stuck behind the thermostat.nismo_power wrote:...im sure there is no air in the system...
I also use this method...DevilMB3017 wrote:That isn't how I've ever gotten air out of a coolant system...
Take the cap off the top of the radiator, turn the car one with the heat on all the way. As your car warms up, the coolant will flow and the radiator will bubble. Some coolant may come out and go all over the place. As it happens it'll settle back down. Throw some more coolant in it until it stops bubbling is at a high enough point. Turn the car off, wait a little bit, and put the cap back on. And then start driving.
This is horribly wrong. Driving without a thermostat can cause problems from not letting your car get up to operating temps and constantly having a lot of coolant flowing. Please do not listen to this advice. I have never had a problem with buying good thermostats.drftman wrote:this happens to everyone with 240's including me i just drive with no thermostat i got tired of buying them becase of them going bad.
honestly i dont see any problem in this besides warming up a little slow but since i've been turbod even w/out a thermostat the car warms up pretty fast and i have a koyoracing rad. And i'm talking about cold mornings. i also have a old 83 toyota pickup(300k miles) w/ out thermostat and been going on w/ out thermostat forever now w/ out a problem.DevilMB3017 wrote:
