ka24de into a truck
fast_s13
has anyone ever put a ka24de in a hardbody truck if so what all has to be done to change it
tloof
Car: Flying & performance cars
I'm working on a KA24DE conversion into my '85 Nissan 720 truck right now (I previously had swapped a KA24E version into it), but it is very similar to what you will encounter in the Hardbody conversion since I did use a '95 Hardbody wiring harness in my E conversion, and with a few changes I will also use it for the DE conversion as well.
One vital thing that I have to point out to you, and that is that you HAVE to use a Frontier DE engine for the Hardbody conversion because the truck DE block has the required rear sump oil pan that will fit into that chassis and clear the steering linkage (a 240SX version will NOT work because of the front sump design...which includes the timing chain cover). You can swap the 240SX intake system onto the Frontier engine, but the power steering bracket will have to be cut off at the back to clear, and the ECU coolant temp sensor and coolant temp gauge sender have to be relocated to the top side of the intake manifold to clear the power steering pump itself. Also a very complicated custom intake tube will be required to be made to clear the power steering pump (I made mine out of 2 3/4" mandrel bend exhaust tubing that I later had CAD plated...fits like a glove in the very tight installation that the 720 is, but the Hardbody has way more room in it than my 720 pickup!!).
Jamesmartin
Car: 1991 240sx s13 ka24de
doesnt one of the nissan trucks come with the ka24de. I think that it is the nissan frontier or something like that. My friend uses it for his business as a delivery truck.
pregmantis
you want to get the truck block because there are issues with the oilpan(as stated earlier) and issues with starter/flywheel mounting.
nismopu
Car: 1987 Nissan 300ZX
1997 Nissan Maxima
1976 Datsun 280Z Turbo
240sx front sumps have been made to work just fine but yes the frontier block is easier. The only reason it is because its SOHC based but with the features of a DOHC, like oil piston squirters. peace.
