KA24DE Intake
LaughingBull
Car: 97 240sx
72 521
77 620
74 cb550
76 cb550
I'm going to be putting a s13 ka in my datsun and am removing all the unnecessary connections from the intake. I searched and only really came up with info for egr removal. My question is what function does the section in the picture serve.
LaughingBull
Car: 97 240sx
72 521
77 620
74 cb550
76 cb550
Nm figured out its the pcv valve. Guess I'll keep this on.
seang
Car: Ford Fiesta ST
It wouldn't hurt to clean out the PCV manifold, though, to make sure it isn't clogged with oily gunk.
LaughingBull
Car: 97 240sx
72 521
77 620
74 cb550
76 cb550
Yeah, thinking I'll clean that up and vent it to atmosphere, then weld the bungs on the intake closed, and remove the butterfly valves.
LaughingBull
Car: 97 240sx
72 521
77 620
74 cb550
76 cb550
Rather then start a new thread I thought I'd continue this one, does anyone see a problem with running the pcv line to a catch can and then to the brake booster outlet for vacuum. As my datsun doesn't have a brake booster I thought this might be a good compromise for ditching the tree under the intake.
seang
Car: Ford Fiesta ST
The problem I see with that is: With the stock setup each runner gets its own share of the PCV gasses, and with the brake booster source they might not, but I'm not too familiar with the DE induction setup as I have a truck E.
LaughingBull
Car: 97 240sx
72 521
77 620
74 cb550
76 cb550
Yeah I actually thought of that too, using that spot would mean cylinder 4 would get be getting the majority of it, but I wasn't sure how much gas there really was. After seeing the crud build up, just trying to figure out a diff way of doing things, maybe stock is the best way of doing it.
