Bigvinnie »
https://forums.nicoclub.com/bigvinnie-u27626.html
Wed May 03, 2006 5:36 am
I don't believe the runners to the KA need any type of serious honing. Just a lite grind to remove any type of burs and imperfections that were in the cast. Increasing the diameter width too much decreases swirl, which actually hurts the atomization process. The intake ports to the head on the other hand can use a slight port job(very miniscul), using a grinding method only(NO polishing). The metal should remain rough to help allow air and fuel to mix as it passes by the valves. Remove imperfections around the valves and port opening. Exhaust side can use a bit of porting only since the exhaust gasses are heavier and hotter , than O2 by itself you would want tem to pass through sooner, you can actually polish the exhaust ports and make them smooth. Although increasing the exhaust ports to large in diameter can cause lack in flow, can cause the engine not to pass smog, and if the ports aren't even then it can also cause scavaging to become unbalanced from cylinder to cylinder. Use caution when doing this type of work. Always get it flow benched when you are done.....
