ka24de intake butterfly system?
weird240
Car: 91 redtop 240fb sold. 91 240sx fb, 95 tercel(flat black beater)
so iam in the process of rebuilding my ka24de. iam planning on doing a ka-t in a month or so but for now its just going to be a daily. ive done some research and have found that when i do my turbo i will have to remove the butterfly system form my intake. my question is if i use it for a daily for the next 2 months should i just take off my system now or wait till i get my turbo on? will it f*uck with my idle?
r3v_v3ng3
Car: 91 fastback ka-t
if your planning to take it out in the future, might as well do it now. since you have the manifold out it'll be easier to plug it. i think it'll only affect the torque not your idle.
96NismoZ
Car: 1996 300zx, 1992 240sx
r3v_v3ng3 wrote: i think it'll only affect the torque not your idle.
in a good way or bad way??
r3v_v3ng3
loss of torque in the lower rpm so i'm guessing bad
Shabbernigdo
i dissabled my secondarys and i can say there is a loss in the low range but its not major but it is a little noticable.
This is on a stock ka24de.
Between 1 and 2 k you can kinda feel it but after that its not really noticable.
96NismoZ
so i removed my secondaries... does anyone take out the shaft the butterflys are on? i tried to do mine, but only got 25% there and its jammed. this is on a spare intake plenum i have...
Shabbernigdo
yes the the butterfly shaft is removed and the little holes it leaves in the mainfold are sealed up
r3v_v3ng3
there should be a screw in the middle between the no 2 and 3 cylinder. dunno if you took that out.
96NismoZ
I did remove that screw but it still won't budge. What have you guys used to seal those holes up??
atownnismo240
Car: 92 hatch
i didnt plug my holes and it runs the same a** when i plugged the holes on my old one
