Ka24de injectors and intercooler piping question
nissan240boy
Car: 1992 nissan 240sx, ka24det , hicas 4 wheel steering, welded rear, konig rims, aftermarket 3 inch cat back exhaust, t3 t4 turbo, tomei fpr, emance ecu, 255 fuel pump, gauges afr and egt and boost
First I need injectors for my 240sx ka24de, now are the injectors the same in other nissan cars that have the ka24de. Now second question can I use steel exhaust pipe for intercooler piping since I can get it a lot cheaper and is 2 and a half a good size pipe?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
As far as the pipe, you can use anything from mandrel bent (you will have to buy the bends and put together your own kit, no one will have a mandrel bender for big pipe), steel, aluminum, exhaust pipe whatever. Me personally, I use exhaust pipe. As far as size I would stick with the inlet and outlet of your intercooler, turbo, tb etc. precision makes a intercooler rated for 700hp and only has 2.75 in and out. The larger the pipe the more laggy the turbo will feal.
nissan240boy
Ok cool, and actually I know a garage that bends exhaust pipe up to 3 inch, ive had him bend up to 2.5 before and he charges 6 bucks a foot and 3 bucks a bend, so not a bad deal
compactfean
daily
Yeah, no one in northern nv has a mandel bender but I know a guy that does the $3 a bend thing also. Don't forget to have them weld a lip, bottom and top, so the couplers don't pop off.
nissan240boy
Ok good idea and I can do that I have a welder
