milto0n »
https://forums.nicoclub.com/milto0n-u172657.html
Sat Mar 03, 2012 9:29 pm
I'm having quite a bit of difficulty with these o rings on my buddies KA.
Abridged version: Keep tearing injector o rings. Possible causes?
More detailed version: It started a couple of weeks back when cylinder 2 (towards the nose of car) wouldn't fire. Pulled each spark plug and each injector cable to verify. Each cylinder was getting spark. The exhaust reeked of gas. Pulled that injector, replaced it with a spare injector and put on brand new o rings. In replacing o rings, we lightly coated it with new oil. Ran fine... for a day after that. For the next week or so, each injector was going bad (at random) so we pulled each injector and replaced with brand new injectors with new o rings of course. Ran fine for another day before the symptoms returned (car running pig rich, skipping random cylinders, tearing o rings) We pulled the fuel fail and replaced the fuel pressure regulator, replaced the o rings this time lubricating them with vaseline and inspecting the inside of the fail (looked fine to me, no barbs or irregularities.) As of now, the car is still doing the same thing, tearing up LOWER o rings and running rich. Just as an added bonus, we've done an oil change as the oil reeked of gas. We have removed the spark plugs in an effort to allow the gas to evaporate seeing is the engine has been flooding. One last piece of info, when installing the injectors, we alternated in screwing it down, half turns at a time and exercised much caution in installing everything as to not tear more o rings.
Help would be greatly appreciated. Please, and thanks.
