ka24de in '89 240sx
jokenessmonster
What else besides engine, wiring harness, and ECU must be acquired to swap a ka24de into my '89 240sx? Same block same engine mounts?
Zerodhero
Just out of curriousity, why would you do that? if you are going to spend the time to do this, why not just do a SR20DET or something, becuase you are going to be halfway their. The engine mounts line up, you need the ecu and wiring harness but if you want to keep power steering and ac, you need to acquire the lines from a car that came with the KA24DE. Same as a standard SR20DET swap.
jokenessmonster
Here in Ca we have Pick 'n' Pulls which charge $170 for everything from the flywheel forward including accessories, $30 for wiring harnesses, $30 for ECU's. If you can do an sr swap for this much hook me up! I can do all the work myself and it's all legal sr20's are not. Not too mention I want to turbo this engine so I can give all those jerks around here with sr20's (cus really around here they're all jerks) a heart attack when they're getting smoked by a "truck" motor. The look on their collective faces will be worth the effort to me.
