Postby nissan2.4 » Thu Sep 13, 2007 2:28 pm
It sounds like ur distributor is off a couple of teeth. Easiest way to figure out if this is ur problem is, removed both bolts that hold ur dist in place, start ur engine and rotate the dist clockwise or counter and see if it gets better, if it does, ur dist is off some teeth. This is the most common problem with the KA, especially since you say its a different motor. The reason why this is very common is cuz on the KA, the dist and the idler gear for the cams has teeth all around and they are al the same, so the dist can go on any way Just one tooth of and it will not run good. Many other engines have slots on the cam which the dist can only go on one way. Lucky US!!
