Chukidori »
https://forums.nicoclub.com/chukidori-u62572.html
Tue Jul 31, 2007 11:01 am
Check timing, and have a compression test done.
If timing is good , and since all other things are good....chances are you could have a valve issue....Which will show up on a compression test.
I had my head cleaned and rebuilt, it skipped real bad at idle..it was basicaly running on three cylinders because of a bad exhaust valve on #4 cylinder..on the compression stroke all the fuel/air mix would get pushed out of the exhaust valve......XD
Modified by Chukidori at 2:16 PM 7/31/2007
