ka24de idler sprocket size for heli coil
whitebride91
Car: 91 240sx fastback
i've searched many forums and sites but i cant find the exact size for the idler sprocket bolt. i acidently stripped the threads from the head and im going to heli coil it but i dont know the size for it. all i know is its a metric bolt size 12 but by what? i tried a M12 X 1.75 from napa and the bolt will get stuck in the heli coil about 1/4 way through. so im guessing its either a M12 X 1.50 or M12 X 1.25. these things are expensive but i need it soon. which is it?
lrb_2000
Car: '91 Nissan KA-T hatch
I did the same thing lol. I can't remember what size of hellicoil I was going to use, but I ended up just getting a longer bolt and using that. The threads go way in there, further than the stock size bolt can even reach.
Papi Chulo
Car: 72' Datsun 510
Why didn't you take the bolt to napa and find a nut (or ask them the size) that fit it in the first place?
I would just buy a bolt to the same size you helicoiled to (m12x1.75). Unless it's a special bolt*i have no idea wtf an idler sproket on a KA looks like*
A *x1.75 and *x1.50 might require a different drill size, you might run into problems if you try and go to 1.50. (not 100% sure)
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
My friend just stripped his and we had to have it drilled and coiled. Its a M12x1.25
whitebride91
thanks for all the replies. ill give the X 1.25 a try. btw, the Napa i went to doesnt have the m12X1.25 in their inventory and catalog but they have all the other sizes.
nopowernolan
Car: s13
Do you remember what size drill bit you used and what size tap you used? I didnt buy the kit, only the inserts so now i need to find out what size drill bit and tap to use... and i cant find this info ANYWHERE online... :mad:
