Postby
2FIZZLE »
https://forums.nicoclub.com/2fizzle-u30308.htmlThu Jul 14, 2005 11:25 am
I have a 92 240sx w/ a ka24de and I am having an idle problem. I just did a head gasket on it and i can't get the timing set because of the idle surging. I made sure that all of the vacuum lines were attached, so I'm pretty sure that it isn't a vacuum leak. What I really need to know is how to adjust the idle.
Postby
EstoMax »
https://forums.nicoclub.com/estomax-u17537.htmlSun Jul 17, 2005 7:31 am
sean8564 wrote:Air idle control valve is a big problem with the KA check it to see if it is bad.Also did you do the timing chain wile you had the head off.
how do u tell if its bad ? cause mine doesnt seem to change the idle at all if i turn it.
