KA24DE high rev problem
JS14.5
Car: '95 S14.5
I've had this problem for a while and couldn't find the problem.I can't rev past around 5K without it making a metal-like sound screeching noise.I've done some research and couldn't find a definite answer.Could it be the timing chain?Just thought I'd ask since some of you guys are 240 gurus
mksue3240sx
Car: 240sx
If your upper timing chain guide is gone and your cam chain is stretched enough it could do that. Pull your valve cover and take a look.
JS14.5
Car: '95 S14.5
Thanks!how much do you think it will cost to get a new guide/chain
JS14.5
Car: '95 S14.5
I haven't checked yet, but most likely I'm going to have to replace the upper.So my question is, should I also replace the lower while I'm at it?
mksue3240sx
Car: 240sx
May also be your lower timing chain and guides. Make sure to change the tensioner too. Plan on 200 or so in parts and a full day of wrenchin.
JS14.5
Car: '95 S14.5
Probably more around $300 for the timing kit and a new headgasket.Should be pretty easy, just real time consuming lol
