ka24de help with removing evap system if possible
jessekincaid27
Car: 1992 Nissan 240sx S13 fastback Ka24de
I was wondering if there was a way that i could remove the coal canister and fix my idle problem its bouncin from 1500 to 2000 please help im sure every one has been through this once or twice its my first 240 and my only problem so far on the ERG there is a metal tube goin from the intake mani to the exhaust mani when i searched for a solution to the high idle the pictures didnt have it on there it was just plated off and sealed??????????????????????????
RXXXII
Car: R32
When I did a rebuild for a friend on his S13, we pulled the motor out, rebuilt it, then upon reinstallation we did a few things regarding the emission system.
First and the most tedious thing that had to be done was to remove the butterfly plates in the intake. We removed everything. Rod and all. Then all the emission holes were blocked off. Lastly we simplified the vacuum line setup.
Cold start became a living hell. LOL! but after warm up seemed to run fine. No dyno sheets to tell you how much of a difference it made though. not much I'm sure.
