KA24DE help!!!
mattaltima99
Car: 1999 Nissan Altima KA24DE, Spectra Cold Air intake, OBX 4-1 Headers, OBX 10.36 Spark Wires, Flowmaster super 44
hi need some help. recenlty got a whole KA from a guy going to put it in a s13. the thing is stuck!! i cant turn it over. i took the oil pan off to look at the pistions they got a little build up around them. but i dont know what to do in order to free all of the pistons. plan was to rebuild the ka up. any suggestions on what pistons and rings to put in it, a guy was telling me NPR off of ebay for the rings(sounds cheap). thanks
240sxrunna2
Car: 1991 s13 project car 07 Audi A4 DD
i used a 2x4 and a hammer when i rebuilt my KA. i took the crank off sprayed some pb blaster on the top side of each piston let it sit for like a half hr and they came out fairly easy. good luck :cool:
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
took the crank off? If you got the oil pain off, spray it down with brake clean and get the build up off, then lube the cyl walls (oil in a spray bottle). Then pull the spark plugs and spray the ringlands with PB blaster and follow it with a 1/2 cap of motor oil, wait and turn the crank with the plugs out.
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
Pull the plugs out and see if it's any easier to turn
mattaltima99
The plugs are out and the crank is free(not totaly off) but the pistons are still not moving after i hammer them with a extension i had them soaking in Deep Creep for 4 days. im stuck???
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Well you just ruined that motor if your hammering the pistons.
mattaltima99
no not really hamering, but the plan is to put wiseco pistons and eagle rods for a turbo ka. just thought if there was any alternatives to saving this block but i guess not. ill find another block thanks for your time
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Crazy.... just fill the tops with PB blaster... should get it loose and okay for honing.
mattaltima99
Yep sounds good i got them out with a bar and a hammer they slid out putting wiseco and eagle rods thanks for the time
