rogoman »
https://forums.nicoclub.com/rogoman-u37451.html
Mon Apr 07, 2008 6:01 pm
You need to determine if there was a loss of fuel or ignition.
The fuel pump may have gone bad or the filter is plugged up. An easy way to test the fuel pump and filter is to disconnect the fuel hose from the top of the fuel filter and insert a long length of spare hose into the top of the fuel filter with the other end draped over the fender going into a catch can placed on the ground. Now turn the ignition key to the run position but DO NOT START THE ENGINE. You should see fuel going into the can at a good rate for several seconds.
Test each spark plug wire for spark by using a spare plug. Connect the plug to the wire and lay on top of the valve cover. Turn the engine over and check for spark.
