ka24de head on ka24e....WORTH IT?
Takumi788
Car: 1992 240sx Vert - sold
1990 240sx Hatch - sold
i have done a lot seaching and happen to have a dohc hanging around and was wondering if this mod is worth it.
my sohc that is in my s13 has 73,000 miles on it. and i need a little more power before i swap the sr in it winter.
i know the compression ratio is increased to 11:1 but i was wondering about hp and torqe gains. do u think i would break 200hp?
mac_daddy
Car: 92 slicktop n/a
i was trying to do the same thingis it even doable?
Takumi788
yes its possible. and i beleive it to make a serious difference. but i would really like to know how much of a deffrence.
any help or knowledge would be helpful.
thanks
Unstock240
Car: 89 240sx se
You need quite a bit of the dohc to do it. Timing cover oil pan chain head and maybe computer and a few other things. I would only do it if say you had a blown ka24de but a good ka24e block. Not really worth buying everything needed unless you get a hell of a deal. When you do this I hear it makes 11:1 compression which would require premuim gas or something like that. I thought about it myself, but going sohc turbo instead.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
That seems very interesting. I would do that in a coupe or something.
Guappone240
Car: 1989 Nissan 240sx
If I'm not mistakin. You can't put a ka24de head on a sohc block the coolent jacket don't match up just look at the gaskets that should tell you especially the forth cyln.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
Guappone240 wrote:If I'm not mistakin. You can't put a ka24de head on a sohc block the coolent jacket don't match up just look at the gaskets that should tell you especially the forth cyln.
the gaskets are the same..the 4th cylinder is the flow throu area..all other cylinders should only have super small holes..as the coolant is ment to flow from top to bottom and front to rear then back to front again...
mac_daddy
well i have a blown de i was gonna build for a ka-t but would it be worth it to just swap the head and all that other stuff? how much power could u really get out of doin this? like takumi788 said, would it break 200hp? and do u guys think its worth it?
Guappone240
the gaskets are not the same. look at the flow on cyln 4 compared to a ka24e. on an e engine there is no slots around the cyln and on the de there is it's not rocket science. look at the gaskets. I'm telling you the head won't match the block.
Takumi788
Guappone240 wrote:the gaskets are not the same. look at the flow on cyln 4 compared to a ka24e. on an e engine there is no slots around the cyln and on the de there is it's not rocket science. look at the gaskets. I'm telling you the head won't match the block.
i have done a lot of searching. it has been done. so....search before making assumptions of what cant and can be done by the way the gaskets look.
Guappone240
Sorry, I was wrong. I just read the thread about the swap. There is a ton of other small s*** that you have to swap. Sounds bother some. But hey maa go for it. Let us know how it turns out!
