NISSAN240SX12 wrote:make sure that you have your engine set at TDC. your almost there you just need to turn the crank a little bit more. mark your distributor exactly were its at once the engine is at TDC. make sure to take pictures of everything once all this is done. on the cam timing there are marks on the sprokets. theres suppose to be 8 chain links between each mark. bag all your bolts so you know what goes where when putting her back together. Yes the intake mani can stay on the head. its easier that way anyhow. take your time with this and dont get into a rush otherwise you'll just f*ck it up. also don't buy any cheap ebay head gaskets! if your unsure on something look it up in the FSM or ask. don't asume anything. good luck!
Okay how can i turn the crank since i have everythin unplugged?..and i already took out the distributor..i have the fel-pro head gasket from autozone..thanks for the info
edit- what bit and size do i need to remove the head bolts?...
Modified by N1sm0zx at 1:07 PM 8/28/2009
