I posted this in the NOM forum but no responses for a week so I figured I would try here:
So I'm replacing the head gasket and I get to the point where I need to install the upper timing chain and cam sprockets. However, the FSM says that the upper timing chain should have 3 mating marks, but I can only see 1 on mine. It's just a chain link that is a different color right? Any ideas or should I just buy a new upper timing chain?
Also, does anyone have a picture of the back of the engine / intake manifold fully put together. I'm trying to figure out the vacuum lines but the diagram and picture in the FSM don't make it very easy.
Alternatively, could I just remove all the vacuum lines for the SCV and EGR on a stock engine? I have already removed the secondary butterflies and the PAIR valve.
