wang wang wang wrote:i thought you can only bent rods from hydrolock or from a broken timing chain..but maybe those pistons can cause it. idk.
and if it was a bent rod, wouldnt it be knocking as soon as i started the first time?
yes, not likely, not likely
yes and no. sometimes the noise from a bent rod will knock.. but if it's not that bad, then it will not be as noticeable. could be mistaken for the normal high mileage dual cam noise that the head likes to make.
seriously... do a leakdown test on the cylinders... if your school doesn't have one... then you shouldn't be rebuilding engines there.
