PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Mon Nov 09, 2015 11:39 am
Welcome to NICO!
You should disconnect the battery for 15 or so minutes to clear all your long term fuel trims and idle solenoid targets after you cleaned the MAF and IACV.
It would be good to know if your vehicle is adding to much fuel, not enough fuel, or poor spark that is leading to the no start condition.
Try keying-off and on 5 or so times without starting. This should prime the fuel system and fire the injectors slightly. If that fixes your problem, let us know.
