ka24de gauge cluster problems
jdmtim
Car: s13
i just did a sohc to a dohc swap and im trying to figure out a way to get the rpm gauge to work i already put the dohc rpm gauge in my sohc gauge but it still doesnt work... i also have a digital gauge with hud... thanks
214kka-et240sx
Car: nissan s13 silvia
jdmtim wrote:i just did a sohc to a dohc swap and im trying to figure out a way to get the rpm gauge to work i already put the dohc rpm gauge in my sohc gauge but it still doesnt work... i also have a digital gauge with hud... thanks
do you mean the whole cluster?, you also have to change the wiring harness, from the dohc, and take off the sohc, cuz thats way it doesnt work, does you speedometer work?
jdmtim
Car: s13
i have the sohc cluster with the dohc rpm gauge inside it... so theres no way its going to read the rpm:( and yes speedometer works everything works just the rpm gauge doesnt
RPS13_Shift
I have the same problem, I swapped my engine 200 miles later my RPM gauge on the clusters shuts off on me, where is the RPM line connected so I can check for problems
