KA24DE Gasket locations
a1montee
Car: 1989 KA24DE Swaped 240sx.
Ok so this is my first swap and my first 240sx, sorry for the noobness.
I know where most of the gaskets go that are obvious, but in my full gasket set I bought ive got little O-rings, and smaller gaskets that im not sure where they go.. Ive been following my FSM but its not very specific... Is there any information or list or something that can help guide me as I put my motor back together.
sean9497
Car: 1992 240sx Fastback
O rings may be the injectors. If the o rings go the injectors act up. When throwing on gaskets, try getting permatex high tack gasket spray. Makes it much easier. Good luck. They can only fit perfectly in one place.
waxdnuggz
Car: 90 240sx hatch SOLD
91 240sx hatch SOLD
92 super sweet daily (freezing cold a.c., working ps and pw)
93 240sx hatch SOLD
94 240sx vert SOLD
Um... pictures?
corey170
Car: 91 240sx 5spd KA24DE h/b (current)
89 240sx A/T 2.4L (old)
one of the small "triangle" shaped gaskets is for your thermostat housing. Injectors have O-rings and insulators I think, so if there is 4 little things then they are probably for your injectors. Post a picture of the ones you don't know and I bet you will instantly get an answer
