KA24DE Fuel Rail and injectors
bayamonboy1986
Car: 1991 240sx fastback, 2002 Civic LX
Im pretty much keeping my 91 240sx ka24de engine stock, jus having problems with the idle. Im thinking of picking up a new fuel rail and replacing the injectors with stock s14 injectors from my 95. Injectors are a bit pricey right now and i just plan to daily so i dont see much reasoning behind spending $300ish on some. Im looking for some feedback as to what fuel rail to pick up and if the s14 injectors will be good enough.
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
Do you know for certain that it's the injectors giving you the problem?
Crazyirish
Car: Nothing noteworthy at the moment...
Yeah, what scotty said. I wouldn't replace something as expensive as that unless I knew it was the problem.
bayamonboy1986
i know for sure one injector was bad, so I switched it out with one from my zenki. So i figured id switch out the others this weekend.
BigDAT
what you should do is just ask your friend if you can switch all them out with him just to check if that is the issue, if it works fine, then buy your own set. that is if he is ok with that...
Patarach
Car: 240sx convertible KA-T
I have about 12 spare ka24de injectors if you cant find any. ha ha. I would not even remove my fuel rail unless you have a vac leak on the lower seals or something.
bayamonboy1986
yea ima jus change out the injectors from my s14. Plan on pullin its engine and selling the shell anyway
