yohnp »
https://forums.nicoclub.com/yohnp-u136601.html
Mon Aug 09, 2010 7:33 pm
S13 KA24DE
OK so i know this has been discussed before.YES I SEARCHED but i haven't read anything that has a solution to this... i need someone to help me out with my problem i'm having.
1. my fuel pump is not priming, yes i checked fuses, relay.all good n replaced. and nothing.
checked wiring. seems fine. checked black n pink wire.. and once i connect it directly to ground pump works but does not STOP... seems like some how there's no signal going to pump which is the black and yellow wire.. off relay to pump.
2. My motor cranks but no spark... plugs are good cables are good , im thinking maybe coil ignition , power resistor?
question is there suppose to be power signal from ecu to dizzy or coil ign ? tryed checkin with test light and theres nothing
cheked grounds with ohm
sorry if i sound like a stupid noob.
but this never happen with my old motor.
do i have a grounding problem wtf please hel
