nothing wrote:The car starts everytime but I have noticed that its becoming a rougher start. Like theres too much gas or something.
So, I should pull out an injector while my engine is running? Wont this cause gas to leak everywhere from the injector that is no longer in place? Are you sure I shouldnt be pulling out a spark plug wire?
What else can I look for to find my faulty injector(s) if my reading of 5.9 ohms isn't enough proof? I'm guessing maybe a black spark plug for that cylinder. Is there anything else or can someone else confirm that my car wouldn't be starting with two faulty injectors?
Thanks everyone!
Dont pull the injector its self off just the plug in the back the powers it and see if u notice any change in the way the engine is running.
If its running rough just pull the plug off the back of the injectors one by one till u get to the one that doesent make a diff in the way your engine is running when its un pluged and that will be your bad one.
