KA24DE ENGINE PROBLEM"S NEED HELP
irishmarc18
Car: nissan 240sx
like the title says , to be specific i put some mod's on my s14 firstly the cold air intake , new sparkplugs and wires and a powdercoated hotshot header. When i installed the header it came from another s14 but the EGR hose would'nt connect so i bought a EGR block off valve and there was no more hot air being disburssed throughout my engine im not sure if that was the cause but earlier this year i replaced my water pump and noticed the slightly decrease in water in my radiator the night before the engine gave out, i came home from work and noticed some smokei knew it was my radiator overheating but i drove it the rest of the way home and when i turned off the car , of course it was somokin bigtime so i could'nt touch it for a few hours before i could replenish the radiator with fluid's but the next day i was running late to my second job and the car stalled when i came to a stop sign i started it back up and kept driving it kept dying out whenever i came near a stop i just wanted to make it to work then i noticed the car losing power i was doing 60mph @ 4rev's and i downshifted to see the boost , i tried to make it to my job when the engine stalled and it would'nt start up again , since then ive done everything i can i was told that the egr block off could have been building to a serious break and having no water or fluids in the radiator just tipped it over , please if you have any info let me know i'd really like to keep my engine and restore it , i've already bought a turbo for the KA24DET build PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! A FELLOW NICO CLUB AND NISSAN ENTHUSIAST OUT PLEEEEEEEAAAAAAAAAZZZZZZZZZZZ.
S13DrIfTmEkAnIcS
Car: 89 240sx
when u changed the water pump did u keep the clutch fan? and u didn't see any puddles under ur car when stopped for a bit?? i've never heard of an egr block off messing up anything. all it does is send exhaust gasses back though the intake (stupidest thing invented). my 240 has a blockoff and i encourage every other 240 owner to do the same. is it leaking oil at all or smoking out the tail pipe?? and did u change ur thermostat?? needed info to help u out
seanman
Car: 1989 Nissan 240sx
might the egr do anything like the pcv valve? like sending some unwanted things in your engine back in to be pushed out the pipe?
irishmarc18
Car: nissan 240sx
i kept the clutch fan , no puddle's though i was loosing the water , i would'nt say rapidly but more stranger than normal and i did change the thermostate , i was told to try a number of things to find out if i got water in my head's , like taking out each sparkplug and sticking my finger down there and have someone crank the engine and see if any water shot up but i havent tried that yet , oh , i didn't remove the other piece that looks similar to a egr valve (looks like a bell copper color ) i didnt remove that piece and did'nt know where or how to go about disconnecting it.
irishmarc18
Car: nissan 240sx
is the pcv valve located right next to the egr valve , im not sure but it is connected still but the tubes that would be connected to the egr are not connected at all , if im making no sense please let me know and any other suggestions would be very helpful
irishmarc18
Car: nissan 240sx
please people keep with the comments and suggestions ive checked the fuel filter and it is disburssing fuel above and below , throughout the lines , and i also tried spraying starter spray aka ether directly onto and even into the air intake while someone cranked it over , please pep's keep withthe comments , thanks alot
