ka24de engine noise. lifters???
seattlebmxs13
Car: 91 240sx s13
engines making a weird noise. upper chain guides are removed, new chain and tensioner.
maybe its the lifters? its got new bc v2 cams in it.
a few shim clearances are barely out of spec. only one clearance was slightly too large. would not quite enough clearance cause this?
any ideas are appreciated
http://www.youtube.com/watch?v=UbB3_ya0uHQ
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I would re-shim it properly first. It could be a lifers by the whine, but it also sounds like knock.
seattlebmxs13
Car: 91 240sx s13
ugh really? knock? i just put the thing back together...
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
hard to tell from the video.
Get a wooden down and place it on the motor and listen from the other end... old trick
240_dude
Car: nissan 240sx
No its not a knock, A knock is pretty loud. This seems to be coming from the top of the engine. Did you lube the cams properly? If i were you i would stop by a local auto parts store and pick up some STP oil treatment with some castrol 30 wieght oil. Mix it in a contianer and pour it into your engine. this helped my 240sx lifter problem. Cause my cams were changed also. You should give it a try only cost you about 7 bucks
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Rods don't knock overnight. As the clearances grow the knock gets louder. However I think its also the top end, but it sounds like knock at a certain point in the video. You know the shimming is off, reshim, soak in oil, and retry
240_dude
Car: nissan 240sx
Yea thats also true. But if its the lifters stp helps for sure. On top of that you can never know from a video. You have to be there.
seattlebmxs13
Car: 91 240sx s13
thanks for the suggestions guys, i'll try that and get back here...
